| | Les informations | |
+13AimelleB Niko Free Wheelin' Nat Casing Diabolo SKATING deedoff boudi56 Scully PEPEJY Laika Fred Klax 17 participants | |
| Sujet: Re: Les informations Mar 22 Mar 2011 - 21:32 | |
| Info AIEA : "Fukushima Nuclear Accident Update (22 March 2011, 04:15 UTC) Japanese authorities have reported that they will measure radioactivity in the marine environment around the Fukushima Daiichi nuclear power plant. The monitoring will be conducted from 22-23 March by the Japan Agency for Marine-Earth Science and Technology (JAMSTEC). Sea water sampling from eight locations will be sampled and analysed by the Japan Atomic Energy Agency (JAEA), and results will be provided on 24 March. The analysis will include radionuclide concentrations found in sea water and dose rate. The IAEA will continue to follow this information." |
| | | Fred Homme-canon
| Sujet: Re: Les informations Mar 22 Mar 2011 - 21:35 | |
| Info AIEA : "IAEA Briefing on Fukushima Nuclear Emergency (22 March 2011, 15.30 UTC) On Tuesday, 22 March 2011, Graham Andrew, Special Adviser to the IAEA Director General on Scientific and Technical Affairs, briefed both Member States and the media on the current status of nuclear safety in Japan. His opening remarks, which he delivered at 15:30 UTC at the IAEA headquarters in Vienna, are provided below: 1. Current Situation There continue to be some improvements at the Fukushima Daiichi nuclear power plant, but the overall situation remains very serious. High levels of contamination have been measured in the locality of the plant. On the Fukushima site the highest concern remains the spent fuel in the storage ponds of each reactor unit, particularly Unit 4. Reactor Units1-3 remain of concern, in particular Unit 2. We have not received validated information for some time related to the containment integrity of Unit 1 so we are concerned that we do not know its exact status. Grey smoke was observed from Unit 3 which led to the evacuation of plant personnel for several hours yesterday due to elevated dose rates. In addition, white smoke or vapour was observed from Unit 2. Efforts continue in Unit 2 to connect AC to pumps etc. Work for the recovery of off-site power supply to Units 3 and 4 is also proceeding. Seawater is being injected into the reactor vessels of Units 1, 2 and 3. Water is being sprayed periodically into the spent fuel pools at Units 2, 3 and 4 but no information is available for the spent fuel pool of Unit 1. The Agency still lacks data on water levels and temperatures in the spent fuel pools at Units 1, 3 and 4. There have been some positive developments concerning Units 5 and 6 that are in cold shutdown: off-site power is now being used in Unit 5; the pressure of the reactor pressure vessel of both units has decreased; and water is being injected in to the reactor pressure vessel, as needed. 2. Radiation Monitoring IAEA monitoring of gamma dose rates and beta-gamma contamination has continued over the last 24 hours. This has been carried out together with the Japanese authorities to facilitate the comparison of results. The IAEA took measurements at additional locations between 35 to 68 km from the Fukushima plant. The dose-rate results ranged from 0.8 to 9.1 microsieverts per hour. The beta-gamma contamination measurements ranged from 0.08 to 0.9 MBq per square metre. More precise interpretation of the results will be possible based on measurements to be made of the composition of the radioactive material that has been released. In the coming days the IAEA will have two monitoring teams in Japan. One team will be in the Fukushima area and a separate team will undertake monitoring in Tokyo and the surrounding area. The Agency continues to receive data confirming high levels of radioactivity in food, notably spinach, in samples taken from 37 locations in the vicinity of five cities south of the Fukishima site. This indicates that in four Prefectures some food products are above permissible levels. High levels of both Iodine-131 and Caesium-137 have been measured by the Japanese authorities in spinach and some other fresh vegetables, together with Iodine-131 in milk. However, as reported yesterday, distribution of food from the areas affected has been restricted. The Japanese authorities are monitoring the situation in the rest of the country. Further monitoring data will be provided by Japan to the IAEA/FAO on an ongoing basis. Japan's Nuclear and Industrial Safety Agency (NISA) has announced that contamination has been found in sea water samples taken close to the outlet of the Fukushima Daiichi plant. We have been informed by NISA about plans to monitor the marine environment." _________________ Fred I IRSN |
| | | Fred Homme-canon
| Sujet: Re: Les informations Mar 22 Mar 2011 - 21:38 | |
| Info AIEA : "Fukushima Nuclear Accident Update (22 March 2011, 16:45 UTC) Seawater Monitoring - Updated Japanese authorities have reported that the Tokyo Electric Power Company has detected radioactive materials in seawater at one location near the Southern discharge canal at the Fukushima Daiichi nuclear power plant. Samples taken included levels of iodine-131, cesium-134, and cesium-137. To study a larger area of the marine environment, the Japan Agency for Marine-Earth Science and Technology (JAMSTEC) plans to measure radioactivity around the plant from 22-23 March. Seawater will be collected from eight locations, and the Japan Atomic Energy Agency plans to analyse the samples and release results on 24 March. The analysis will include radionuclide concentrations found in sea water and dose rate in the air. The IAEA will continue to follow this information." _________________ Fred I IRSN |
| | | Fred Homme-canon
| Sujet: Re: Les informations Mar 22 Mar 2011 - 21:57 | |
| Info AIEA :" Fukushima Nuclear Accident Update (22 March 2011, 18:00 UTC) Spent Fuel Pools at Fukushima Daiichi Nuclear Power Plant - Updated Spent fuel removed from a nuclear reactor is highly radioactive and generates intense heat. This irradiated fuel needs to be actively cooled for one to three years in pools that cool the fuel, shield the radioactivity, and keep the fuel in the proper position to avoid fission reactions. If the cooling is lost, the water can boil and fuel rods can be exposed to the air, possibly leading to severe damage and a large release of radiation. Nuclear power plants must replace fuel every one to two years, and the Fukushima Daiichi reactors typically remove about 25 percent of the reactor's fuel - to be replaced with fresh, or unirradiated, fuel - during each refuelling outage. The spent fuel, which is hottest immediately after it is removed from the reactor, is placed in the spent fuel pool until it is cool enough to be moved to longer-term storage. The concern about the spent fuel pools at Fukushima Daiichi is that the capability to cool the pools has been compromised. See diagram below for location of the pool in each reactor building. Elevated radiation measurements at the site may be partially of the result of uncovered or overheated spent fuel.
Number of Fuel Assemblies in Cooling Pools at Fukushima Daiichi (Reported 17 March by Japan's Ministry of Economy, Trade and Industry) Capacity / Irradiated Fuel Assemblies / Unirradiated Fuel Assemblies / Most Recent Additions of Irradiated Fuel Unit 1 900 / 292 / 100 / March 2010 Unit 2 1,240 / 587 / 28 / Sept 2010 Unit 3 1,220 / 514 / 52 / June 2010 Unit 4 1,590 / 1,331 / 204 / Nov 2010 Unit 5 1,590 / 946 / 48 / Jan 2011 Unit 6 1,770 / 876 / 64 / Aug 2010
Here is a summary of spent fuel conditions at Fukushima Daiichi nuclear power plant, based on documents and confirmed by Japanese officials (new information in bold):
Unit 1 Unit 1 experienced an explosion on 12 March that destroyed the outer shell of the building's upper floors. No precise information has been available on the status of the spent fuel pool.
Unit 2 Precise information on the status of the spent fuel pool was unavailable in the days following the earthquake, but Japan's Nuclear and Industrial Safety Agency began to release temperature data on 20 March: 20 March, 23:00 UTC: 49 °C 21 March, 05:25 UTC: 50 °C 21 March, 21:20 UTC: 51 °C 22 March, 02:20 UTC: 53 °C 22 March, 06:30 UTC: 50 °C Workers conducted an operation to spray 40 tonnes of seawater to the spent fuel pool on 20 March.
Unit 3 Unit 3 experienced an explosion on 14 March that destroyed the outer shell of the building's upper floors. The blast may have damaged the primary containment vessel and the spent fuel pool. Concerned by possible loss of water in the pool, authorities began spraying water into the building in an effort to replenish water levels. First, helicopters dropped seawater on 17 March, and every day since then, including 21 March, emergency workers have sprayed water from fire trucks and other vehicles, so far spraying at least 3,742 tonnes.
Unit 4 This reactor was shut down 30 November 2010 for routine maintenance, and all the fuel assemblies were transferred from the reactor to the spent fuel pool, before the 11 March earthquake. The heat load in this pool is therefore larger than the others. On 14 March, the building's upper floors were severely damaged, possibly causing a reduction of cooling capability in the spent fuel pool. Emergency workers began spraying water into the building on 20 March, and have continued daily since then, so far spraying at least 255 tonnes.
Units 5 and 6 Instrumentation at these reactors began to indicate rising temperatures at their spent fuel pools starting on 14 March. Three days later, Japanese technicians successfully started an emergency diesel generator at Unit 6, which they used to provide power to basic cooling and fresh-water replenishment systems. Workers created holes in the rooftops of both buildings to prevent any hydrogen accumulation, which is suspected of causing earlier explosions at Units 1 and 3. A second generator came online on 18 March, and the next day, the higher-capability Residual Heat Removal system recovered full function. Temperatures in the spent fuel pools of Units 5 and 6 have gradually returned to significantly lower temperatures (See graph below).
Common Use Spent Fuel Pool In addition to pools in each of the plant's reactor buildings, there is another facility - the Common Use Spent Fuel Pool - where spent fuel is stored after cooling at least 18 months in the reactor buildings. This fuel is much cooler than the assemblies stored in the reactor buildings. Japanese authorities confirmed as of 18 March that fuel assemblies there were fully covered by water, and the temperature was 57 °C as of 20 March, 00:00 UTC. Workers sprayed water over the pool on 21 March for nearly five hours, and the Nuclear and Industrial Safety Agency reported that the pool temperature had risen to 61 °C as of 21 March, 07:30 UTC. " _________________ Fred I IRSN |
| | | Fred Homme-canon
| Sujet: L’IRSN publie une évaluation de la radioactivité rejetée par la centrale de Fukushima Daiichi (Fukushima I) jusqu’au 22 mars 2011 Mar 22 Mar 2011 - 22:15 | |
| Info IRSN : Pour estimer les niveaux de contamination de l’air résultant de l’accident affectant la centrale de FUKUSHIMA DAIICHI, l’IRSN a dû au préalable évaluer la quantité de radioactivité qui a pu être rejetée du 12 au 22 mars 2011 par les trois réacteurs accidentés. Cette évaluation est conçue pour fournir un ordre de grandeur réaliste de ces rejets, cohérent avec l’interprétation des informations provenant des autorités japonaises ou de l’AIEA, et avec les résultats de mesures sur le terrain, tout en restant fondée sur des hypothèses raisonnablement majorantes.
L’évaluation réalisée, établie sur la base des informations disponibles à ce jour, repose sur : * un diagnostic de l’état des trois réacteurs concernés (compréhension de la situation, état des systèmes de refroidissement…) ; * les connaissances acquises par l’IRSN au travers de ses programmes de recherche sur le comportement de combustibles insuffisamment refroidis ; * sur les informations fournies par les autorités japonaises concernant les dégazages des enceintes de confinement des réacteurs qui ont été réalisés volontairement pour protéger les enceintes de risques de dégradation par surpression. Les conclusions de cette évaluation ont été confortées en comparant les valeurs de contamination atmosphérique calculées par le modèle de dispersion avec les résultats de mesures réalisées sur le terrain au Japon. Un échange a également eu lieu avec des partenaires du réseau ETSON (european technical safety organisation network), l’US/NRC et le STUK finlandais. L’activité rejetée lors des opérations d’éventage des enceintes de confinement des réacteurs concerne les radioéléments les plus rapidement relâchés lors d’une dégradation importante des combustibles (gaz rares, iodes, césiums, tellures…). A des fins de simplification à ce stade, seuls ont été considérés les radioéléments ayant une contribution majoritaire aux conséquences radiologiques en retenant des proportions usuellement rencontrées dans les combustibles irradiés ; l’activité ainsi évaluée est la suivante (cœur composé de 400 assemblages de combustible pour le réacteur 1 et de 548 pour chacun des réacteurs 2 et 3) : * Gaz rares : 2 10+18 Bq ; * Iodes : 2 10+17 Bq ; * Césiums : 3 10+16 Bq ; * Tellures : 9 10+16 Bq. A titre de comparaison, ces valeurs représentent de l’ordre de 10 % des rejets estimés lors de l’accident de Tchernobyl pour ces différentes familles de radioéléments. Il est toutefois à rappeler : * qu’il s’agit d’une première évaluation réalisée sur la base des données disponibles au 22 mars 2011 ; * que les quantités de radionucléides présumées rejetées, exprimées en Bq, ne permettent pas à elles seules de formuler des hypothèses sur les conséquences radiologiques, celles-ci dépendant fortement des conditions météorologiques (une partie du rejet a été dispersée au-dessus de l’océan Pacifique. Enfin, une cinétique de rejet en fonction du temps a été définie, en la calant sur les pics de débit de dose observés en limite de site, pour fournir les données d’entrée des modèles de dispersion atmosphérique utilisés par l’IRSN à l’échelon régional et par Météo France pour les évaluations à l’échelle de l’hémisphère nord. Source[b] - Fichiers joints
- NI-terme-source-22032011-tableau.pdf
- Composition détaillée du rejet utilisé pour estimer les niveaux de contamination de l’air (document pdf)
- Vous n'avez pas la permission de télécharger les fichiers joints.
- (23 Ko) Téléchargé 7 fois
| | | Fred Homme-canon
| | | | Invité Invité
| Sujet: Re: Les informations Mar 22 Mar 2011 - 22:47 | |
| Merci à tous pour les info |
| Sujet: Re: Les informations Mar 22 Mar 2011 - 22:52 | |
| Cliquez bien sur "visionner la simulation" et pas directement sur le graphique pour ne pas avoir de pubs pénibles. |
| | | deedoff Contorsionniste
| Sujet: Re: Les informations Mer 23 Mar 2011 - 6:39 | |
| Miniscule numbers of radioactive particles believed to have come from the quake-damaged Fukushima Daiichi nuclear plant in northeastern Japan have been detected in the Icelandic capital of Reykjavik by Tuesday, the Reuters news service said. Citing multiple diplomatic sources, the report said that radiation from the particles is not at a level that would negatively affect human health. It is the first time radioactive materials believed to be released by accidents at the nuclear power plant have been observed in Europe. The radioactive materials were detected at a facility related to the Comprehensive Test Ban Treaty Organization, a Vienna-based U.N. body for monitoring nuclear tests, it said. ''It's only a matter of days before it disperses in the entire northern hemisphere,'' Andreas Stohl, a senior scientist at the Norwegian Institute for Air Research, was quoted as saying. Stohl said there would be no concern about human health over Europe, according to Reuters Source |
| Sujet: Re: Les informations Mer 23 Mar 2011 - 7:39 | |
| Bonjour L'ASN vient d'envoyer un courrier à l'ensemble des exploitants nucléaires pour que ceux qui sont en capacité de faire des mesures atmosphériques, fassent preuve de vigilance à partir d'aujourd'hui dans leurs mesures. Outre iodes et césium, une liste de radionucléides potentiellement détectables a été donnée. Donc on surveille, on surveille ! KLOUG |
| | | Laika Trapéziste
| Sujet: Re: Les informations Mer 23 Mar 2011 - 8:44 | |
| Et ça continue pour les répliques du tremblement de terre au Japon. Hier, sur NHK, la population était exhortée à rester vigilante face au risque d'une réplique importante suivie d'un nouveau tsunami. Voici un article de ce matin : http://www3.nhk.or.jp/daily/english/23_19.html"Aftershocks hit northeastern Japan Strong earthquakes jolted the Pacific coast of northeastern Japan on Wednesday morning. The Meteorological Agency has issued warnings to the region about the possibility of strong aftershocks from the March 11th quake, saying they could trigger more tsunami. A quake with a magnitude 6.0 jolted Fukushima Prefecture at around 7:12 AM, followed by a magnitude 5.8 tremor about 20 minute later. These were the first earthquakes since Saturday with intensities of 5-plus or above on the Japanese seismic scale of 0 to 7. The agency says that about 70 aftershocks with intensities of 4 or higher have shaken wide areas of the northeastern Tohoku region as well as areas around Tokyo. It says the frequency of the aftershocks is declining but warns of the possibility that tremors of magnitude 7.0 or higher could occur. Wednesday, March 23, 2011 11:01 +0900 (JST)"Une réplique plus important que les autres 6.0 (attention, ce n'est pas l'échelle de Ritcher) a touché la préfecture de Fukushima à 7h12 (heure Japonaise) du matin, suivie 20 mn après d'une moins importante. Il y a une environ 70 répliques jusqu'ici, et bien que la fréquence des répliques diminuent, les autorités n'exclue pas la possibilité d'une réplique plus importante d'un niveau 7 ou plus. Laïka |
| | | Laika Trapéziste
| Sujet: Re: Les informations Mer 23 Mar 2011 - 8:55 | |
| Et pour les nouvelles plus rassurantes, toujours sur NHK, les employés de TEPCO sont en train de remettre en état les alimentations électriques des équipements dans le réacteur 3. Article NHK : http://www3.nhk.or.jp/daily/english/23_20.html"No.3 reactor's pump to undergo test run The Tokyo Electric Power Company, or TEPCO, plans to test-run a cooling pump at the No. 3 reactor of the Fukushima Daiichi nuclear power plant on Wednesday, in the latest bid to restore cooling functions at the plant. TEPCO said the electricity supply for the control room of the reactor was restored on Tuesday night for the first time since the devastating quake and tsunami on March 11th, allowing lights in the room to be turned on again. The reactor is the first among the troubled No. 1 through 4 reactors to have external power restored at its control room. On Wednesday morning, a local TEPCO branch told reporters that it will check whether the pump can supply water to the reactor from its tank. Meanwhile, work to inject water into the spent fuel storage pool of the No. 4 reactor resumed shortly after 10 AM and finished about 3 hours later. TEPCO plans to inject water for about 3 hours using a vehicle with an arm that can be extended more than 50 meters to spray water with great accuracy. The Tokyo Fire Department plans to spray water into the No. 3 reactor for about 2 hours on Wednesday afternoon. Wednesday, March 23, 2011 11:42 +0900 (JST)"L'électricité a été rétablie dans la salle de contrôle du réacteur 3 mardi soir. Les employés de TEPCO essaient de remettre en fonctionnement un pompe d'alimentation en eau du réacteur. Cependant il est toujours prévu que les pompiers arrosent le réacteur 3 pendant 2 heures l'après-midi. Pendant le même temps une injection d'eau à partir de camions citerne possédant un bras extensible jusqu'à 50 mètre continue dans la piscine de stockage des combustibles usés du réacteur 4. Laïka |
| Sujet: Re: Les informations Mer 23 Mar 2011 - 10:33 | |
| - Citation :
- REUTERS/Tokyo Electric Power
Les ouvriers de la centrale nucléaire japonaise accidentée ont été évacués. Alors qu'une fumée noire s'élève au-dessus du réacteur N°3 de Fukushima, les ouvriers de la centrale nucléaire japonaise ont été évacué temporairement. "Les employés ont été évacués de la salle de contrôle du réacteur 3", a déclaré un porte-parole de Tepco.
Selon l'opérateur, il est impossible à ce stade de déterminer si la fumée s'échappe du réacteur lui-même ou du bâtiment contenant la turbine.
"Nous ne savons pas si la fumée vient du bâtiment abritant la turbine ou bien de l'enceinte de confinement du réacteur", a ajouté le représentant de Tepco.
| Sujet: Re: Les informations Mer 23 Mar 2011 - 10:44 | |
| Info des douanes: La mise en place de contrôles renforcés sur les denrées alimentaires en provenance du Japon A la suite des évènements affectant la centrale nucléaire de Fukushima et des mesures spécifiques de protection recommandées par la Commission européenne, la France a mis en place un dispositif de renforcement des contrôles sur les denrées alimentaires importées en provenance du Japon.
Tous les produits d’origine animale et les produits frais (salades, légumes, fruits, etc) sont soumis à des prélèvements préalables d’échantillons et à des analyses en laboratoire, conduits par les administrations concernées (DGAL, DGCCRF), avant toute libération des marchandises par la douane.
Il faut noter que les volumes sont habituellement très faibles.
S’agissant des autres denrées alimentaires, elles font l’objet des mesures de contrôle décidées sur le fret en provenance du Japon.
Les autorités japonaises procèdent de leur côté à des contrôles de radioactivité sur les produits exportés, avant toute expédition.
Page mise à jour le 22/03/2011 par Bureau Information et Communication |
| Sujet: Re: Les informations Mer 23 Mar 2011 - 14:36 | |
| - Citation :
- 14h04. La radioactivité au réacteur n°2 atteint un niveau record
La radioactivité au réacteur n°2 de la centrale nucléaire de Fukushima était mercredi à son plus haut niveau depuis le séisme qui a endommagé l'installation, a annoncé l'Agence japonaise de sûreté nucléaire. Le niveau enregistré était de 500 millisieverts par heure.
info ou intox? |
| Sujet: Re: Les informations Mer 23 Mar 2011 - 14:56 | |
| Sujet: Re: Les informations Mer 23 Mar 2011 - 21:38 | |
| Les infos via l'AIEA
Briefing on Fukushima Nuclear Accident (23 March 2011, 15:30 UTC)
On Wednesday, 23 March 2011, Graham Andrew, Special Adviser to the IAEA Director General on Scientific and Technical Affairs, briefed both Member States and the media on the current status of nuclear safety in Japan. His opening remarks, which he delivered at 15:30 UTC at the IAEA headquarters in Vienna, are provided below:
* There are some positive developments related to the availability of electrical power supply to the Fukushima Daiichi nuclear power plants, although the overall situation remains of serious concern. * AC power is now available at Units 1, 2 and 4. Power has been restored to some instrumentation in all Units except Unit 3. At Unit 3, the main control room has lighting, but no power to its equipment or instruments. As a positive development instrumentation, as it becomes available, is providing more data that can be assessed by experts. * The pressure in the reactor pressure vessel and drywell of Unit 3 is stable. However, pressure has increased in both the reactor pressure vessel and the drywell of Unit 1, where seawater injection has been increased. Until heat can be removed from Unit 1, pressure tends to increase as water is injected. The reactor feed water system is being used, in addition to water injection through fire extinguisher lines. * Pressure readings in Unit 2 appear to be less reliable. Only limited data is available concerning the reactor pressure vessel and reactor containment vessels' integrity of Unit 2. Temperature readings in the reactor pressure vessels of Units 1 and 3 were high and of some concern. The temperature has now dropped in Unit 1 following the start of seawater injection via feed-water pipes. Indications are that the temperature at Unit 2 is stable. * Units 5 and 6 continue to have off-site power and remain in cold shutdown. * Dose rates measured in the containment vessels and suppression chambers of Units 1, 2, and 3 are available and are being studied. * Periodic water spraying of Units 2, 3, and 4 and the common spent fuel pool has continued.
The IAEA radiation monitoring team took additional measurements at distances from 30 to 73 km from the Fukushima nuclear power plant. Results from gamma dose-rate measurements in air ranged from 0.2 to 6.9 microsievert per hour. The beta-gamma contamination measurements ranged from 0.02 to 0.6 Megabecquerel per square metre.
The second IAEA monitoring team has now arrived in Japan. The two teams in Japan will continue to work closely with the Japanese authorities. Monitoring will be undertaken in the areas of Fukushima and Tokyo. Measurements will be taken to determine more precisely the actual composition of the radionuclides that have been deposited.
More data has become available from the Japanese authorities. The measurements indicate that the radiation dose rates at the Daiichi site are decreasing. Absent further releases from the site, this is to be expected as relatively short lived radionuclides such as Iodine-131 decay away. At the Daiini site, small spikes have been observed in gamma dose rate measurements; these are most likely to be the result of releases carried by the wind from the nearby Daiichi site.
The deposition of iodine-131 and caesium-137 varies across some ten Prefectures from day to day, but the trend is generally upward. In contrast, environmental radiation monitoring data in the Fukushima Prefecture outside the 20km evacuation zone, shows mostly decreasing values.
Monitoring of the marine environment is being undertaken by the Japanese Ministry of Education, Culture, Sport, Science and Technology (MEXT). High levels of iodine-131 and caesium-137 were measured close to the effluent discharge points Units 1 to 4 of Fukushima Daiichi (i.e. before dilution by the ocean). Future monitoring will cover eight locations 30 km off the coast at 10 km intervals. Results for seawater and the atmosphere above the sea should be available in the next few days. IAEA experts from the Marine Environment Laboratory, Monaco will assess this data.
Since yesterday, the IAEA has received further information from the Japanese Ministry of Health, Labour and Welfare regarding the presence of radioactivity in milk, drinking water and vegetables. The results of some samples were above the limits specified in Japanese regulations concerning limits for food and water ingestion.
In Fukushima prefecture six raw milk samples, and in Ibaraki prefecture three spinach samples, showed concentrations of Iodine-131 in excess of limits. We understand that the Prime Minister of Japan, Mr. Naoto Kan, has today issued instructions to food business operators to cease, for the time being, the distribution of, and for the public to cease the consumption of, certain leafy vegetables (e.g., spinach, komatsuna, cabbages) and any flowerhead brassicas (broccoli, cauliflower) produced in Fukushima Prefecture. The Prime Minister has ordered food business operators not to distribute, for the time being, any fresh raw milk and parsley in Ibaraki Prefecture.
We have also been advised that the Ministry of Health, Labour and Welfare has encouraged Ibaraki and Chiba Prefectures to monitor seafood products.
The Tokyo Metropolitan Water Office stated that levels of iodine-131 in tap water at a purification plant were found to be above the limits for drinking water for infants but below the level for adults. The Ministry of Health Labour and Welfare, has requested that tap water in Tokyo is not used as drinking water for infants.
So, in summary: there are some positive indications on the site; precautionary restrictions around the site on certain foodstuffs; and monitoring of the environment is continuing beyond the evacuation zone and at sea. No significant risk to human health has been identified.
Fukushima Daiichi Nuclear Accident Update (23 March, 20:00 UTC)
Brief update on state of Fukushima Daiichi reactors
Japanese authorities today announced a number of developments at Fukushima Daiichi nuclear power plant, where reactor cooling systems were disabled following the massive earthquake and tsunami on 11 March.
At Units 1, 2, 3, and 4, workers have advanced the restoration of off-site electricity, and the lights are working in Unit 3's main control room.
Black smoke was seen emerging from the Unit 3 reactor building, spurring the temporary evacuation of workers from Units 3 and 4. The emission of smoke has now decreased significantly.
Crews continued today to use a concrete pump truck to deliver high volumes of water into the Unit 4 spent fuel pool, where there are concerns of inadequate water coverage over the fuel assemblies.
At Units 5 and 6, workers have successfully restored off-site power to the reactor, which had previously reached a safe, cold shutdown status.
| Sujet: Re: Les informations Mer 23 Mar 2011 - 22:15 | |
| Bonsoir Après avoir récupéré les chiffres une montée d'activité volumique en iode-131 jusqu'à 23 Bq/m3 sur Tokyo dans la nuit du 22 au 23 (15 h chez nous le 22). KLOUG |
| Sujet: Re: Les informations Mer 23 Mar 2011 - 22:56 | |
| Bonsoir On trouve sur le site de "libé" les premières photos prises à l'intérieur de la centrale. Elles montrent des techniciens en combinaison de protection anti-contamination, équipés de masques respiratoires. Ils sont dans la salle de commande du réacteur n°2, où la lumière n'a pas été encore rétablie. Et l'inspectent à l'aide de lampes torches. Ces photos ont été diffusées par l'Agence de sécurité industrielle et nucléaire du Japon. Il est possible de trouver sur son site web un déroulé précis des événements vus de cette autorité de sûreté nucléaire. lien : http://www.nisa.meti.go.jp/english/files/en20110323-4-1.pdfKLOUG |
| Sujet: Re: Les informations Jeu 24 Mar 2011 - 14:56 | |
| Deux informations
Un petit bilan chronologique de l'accident
Classements INES : Tranche 1 : niveau 5 Tranche 2 : niveau 5 Tranche 3 : niveau 5 Tranche 4 : niveau 3 Tranches 5 et 6 : pas de classement
Pour mémoire centrale de Fukushima Daiini (2) : tranches 1,2 et 4 : niveau 3 (tranche 3 :pas de classement)
Le 11 Mars : - 14h46 : Séisme magnitude 9,0 à 200 km de la centrale de Fukushima Daiichi et 24 km de profondeur. Suivi d’un tsunami 10’ plus tard Arrêt automatique tranches 1,2,3 en fonctionnement (tranches 4,5,6 à l’arrêt) - 15h42 : Annonce par TEPCO de la perte des systèmes de refroidissement des tranches - 19h03 : Etat d’urgence décidé par le Premier Ministre (P.M.) Japonais - 20h50 : Ordre de la préfecture d’évacuer les populations dans un rayon de deux kilomètres - 21h23 : Ordre du P.M. d’évacuer les populations dans un rayon de trois kilomètres (confinement 3 -10 km) Le 12 Mars : - 5h44 : Ordre du P.M. d’évacuer les populations dans un rayon de dix kilomètres - 15h36 : Explosion (hydrogène) sur la tranche 1. Effondrement du toit du bâtiment - 17h00 : Première détection de débit de dose anormal en limite du site - 18h25 : Ordre d’évacuation dans un rayon de 20 kilomètres - 20h20 : Injection d’eau de mer et d’acide borique dans le réacteur de la tranche 1 Le 13 Mars : - 9h20 : Première dépressurisation (réacteur de la tranche 3) et premiers rejets significatifs - 13h12 : Injection d’eau de mer contenant de l’acide borique dans le réacteur de la tranche 3 Le 14 Mars : - 11h01 : Explosion (hydrogène) sur la tranche 3 - 17h17 : Injection d’eau de mer dans le réacteur de la tranche 2 - Heure ?: Ordre de mise à l’abri des populations au-delà de vingt kilomètre Le 15 Mars : - 6h00 : Explosion sur la tranche 4 (piscine) conduisant à l’endommagement du bâtiment réacteur - 6h10 : Explosion au niveau de la « surpression chamber » (tore) du réacteur de la tranche 2, avec probable endommagement. Evacuation des autres salariés que ceux procédant à l’injection d’eau - 9h38 : Incendie sur la tranche 4 - 11h00 : Ordre du P.M. de confiner les populations entre 20 et 30 km Le 16 Mars : - 5h45 : Incendie sur la tranche 4 - Vers 8h30 : Dégagement de fumée blanche (origine inconnue) de la tranche 3 Le 17 Mars : - 9h48 : Injection d’eau de mer sur la piscine d’entreposage des combustibles usés de la tranche 3
Le 20 Mars : - 6h45 : Aspersion d’eau sur la piscine d’entreposage des combustibles usés de la tranche 4 - 15h05 à 17h20 : Pulvérisation de 40 tonnes d’eau sur la piscine d’entreposage de la tranche 2 - 15h46 : Electricité au transformateur de la tranche 2 - 18h20 à 19h46 : Arrosage de la piscine d’entreposage des combustibles usés de la tranche 4 par SDF (?) - 19h52 : Electricité au transformateur des tranches 5 et 6 Le 21 Mars : - 2h37 : Arrosage de la piscine commune d’entreposage des combustibles usés - 3h36 : Tranches 5 et 6 alimentées en électricité - 6h20 à 7h11 : Dégagement de fumée blanches (origine inconnue) de la tranche 2 - 7h55 : Dégagement de fumée grisâtre de la tranche 3 (origine inconnue) - 8h10 : Evacuation des salariés proches de la tranche 3 - 16h00 à 17h00 : Déversement de 18 t d’eau sur la piscine de la tranche 2
Le 22 Mars : - 7h10 à 8h00 : Arrosage de la piscine de la tranche 3 - 8h10 : Quarante tonnes d’eau pulvérisée sur la piscine de la tranche 2 - 9h20 : Arrosage de la piscine de la tranche 4 par une pompe à béton (bras télescopique) - 10h36 : Electricité au transformateur des tranches 3 et 4 - 17h20 à 20h30 : Aspersion d’eau sur la piscine de la tranche 4 - 22h45 : La salle de commande de la tranche 3 est de nouveau éclairée Le 23 Mars : - 1h40 : Electricité au transformateur de la tranche 1 - 2h30 : Reprise d’injection d’eau de mer dans le réacteur de la tranche 3 pour faire baisser la température - 10h00 à 13h00 : Arrosage de la piscine de la tranche 4 avec la pompe à béton (cent trente tonnes d’eau de mer) - 11h00 à 13h30 : Arrosage de la piscine de la tranche 3 - 16h30 : Dégagement de fumées noires de la tranche 3 Evacuation de salariés travaillant sur laes tranches 3 et 4 Le 24 mars : - Matin : Dégagement ressemblant à de la vapeur d’origine et nature inconnues s’échappant des tranches 1, 2, 3, 4 - Matin : Lumière dans la salle de commande du réacteur 1 - Matin : identification de l’irradiation de 3 travailleurs sous-traitants (170-180 mSv) dirigés vers l’hôpital de la ville de Fukushima
Enfin saisine officielle du premier ministre de l'ASN : En application de l’article 8 de la loi n°2006-686 du 13 juin 2006 relative à la transparence et à la sécurité en matière nucléaire, je vous demande de réaliser une étude de la sûreté des installations nucléaires, en priorité les centrales nucléaires, au regard de l’accident en cours dans la centrale de Fukushima. Cet audit portera sur cinq points : les risques d’inondation, de séisme, de perte des alimentations électriques et de perte du refroidissement ainsi que la gestion opérationnelle des situations accidentelles. Il est complémentaire aux démarches de sûreté mises en œuvre par les exploitants nucléaires sous votre contrôle. Je souhaite que vous examiniez, installation par installation, si des améliorations sont nécessaires à la lumière des enseignements qui seront tirés de l’accident de Fukushima.
KLOUG |
| Sujet: Re: Les informations Ven 25 Mar 2011 - 8:18 | |
| Bonjour à tous
Même si Fukushima disparaît des médias, nous sommes toujours en situation de crise. Les Japonais ont entamé la phase post accidentelle notamment au niveau de la population mais il y a encore beaucoup à faire.
Point de situation le 24/03/11 à 20h00 (4h00 25/03 - Japon), Sources AIEA, METI/NISA, Ambassade de France à Tokyo.
Point de situation sur la centrale de Fukushima #1 (Dai-ichi) :
FUKUSHIMA I – Tranche n°1 : Aucun élément nouveau (l’injection d’eau de mer se poursuit dans le réacteur– température de la cuve toujours en baisse – pression toujours haute)
FUKUSHIMA I – Tranche n°2 : Aucun élément nouveau (l’injection d’eau de mer se poursuit dans le réacteur)
FUKUSHIMA I – Tranche n°3 : Injection d’eau dans la piscine d’entreposage via la ligne de refroidissement et de purification (fin de la projection à partir de camions).
FUKUSHIMA I – Tranche n°4 : Aucun élément nouveau (piscine réputée en eau, mais non refroidie)
FUKUSHIMA I – Tranches n°5 et 6 : Quelques perturbations sur le système de refroidissement du réacteur 5 ont nécessité le remplacement d’une pompe. Le refroidissement a été rétabli à 8h35 (16h35 Japon).
Piscine de stockage commune du site : Aucun élément nouveau.
Blessés / contaminés /exposés officiellement recensés : Public : • au 21/03, les contrôles réalisés sur 75 500 personnes de la préfecture de Fukushima ont révélé une contamination vestimentaire pour 97 cas, contaminations qualifiées comme étant sans conséquence pour leur santé. Personnels et intervenants : • 1 travailleur exposé à 106 mSv + « 17 autres travailleurs exposés à un niveau non déterminé mais sans risque pour leur santé » • 3 travailleurs sous-traitants ont été exposés à des doses allant de 170 à 180 mSv (aux jambes). • 5 personnes contaminées lors des opérations d’injection d’eau, contaminations qualifiées comme étant sans risque pour leur santé • Par ailleurs, TEPCO a dénombré 2 disparus (suite au tsunami), et 22 blessés dont 7 contaminés lors de l’explosion de la tranche 3 du 14/03.
Débits de dose / contamination sur le site Porte d’entrée principale du site : 0,20 mSv/h à 21h00-Japon – en baisse très légère, mais régulière. Contamination atmosphérique d’un prélèvement réalisé à la porte principale le 23/03 entre 2h00 et 2h20 (japon) : 670 Bq/m3 en 131I , 17 Bq/m3 en 134Cs et 13 Bq/m3 en 137Bq (après une certaine stabilité, on note une nette décroissance de la contamination en iode dans les dernières 24 heures, la contamination en césium restant stable).
Mesure dans le milieu marin aux abords du site Aucun élément nouveau
Mesures dans l’environnement au-delà de la zone des 30 km Le Ministère en charge de l’éducation, de la science et de la technologie (MEXT) publie de nombreuses valeurs sur son site internet.
En limite des 30 km autour du site, les débits de doses ambiantes mesurés tout au long de la journée varient de moins de 5 µSv/h au sud du site, à 66 µSv/h au nord ouest du site. La valeur maximale de la contamination des terres de surface a été trouvée le 23/03 à 12h40 à Iitate (40 km au nord-ouest du site) : 1,17 MBq/kg en 131I et 0.16 MBq/kg en 137Cs
Contaminations surfaciques le 23/03 : • Préfecture d’Ibaraki (100 km au sud) : 2.7 Bq/cm² en 131I 0.04 Bq/cm² en 137Cs • Tokyo (250 km au sud-ouest) : 3.6 Bq/cm² en 131I 0.03 Bq/cm² en 137Cs Niveau d’irradiation en légère diminution à MITO (Préfecture d’Ibaraki) : environ 0.30µSv/h à 17h00. Niveau d’irradiation stable à Tokyo depuis le 21/03 : environ 0.15µSv/h. Le niveau de contamination en 131I mesuré dans l’eau de Tokyo poursuit sa décroissance : 26 Bq/l sur un prélèvement réalisé le 23/03.
Classement INES : Les événements concernant les tranches 1 à 3 sont classés au Niveau 5. Les événements concernant la tranche 4 est classé au niveau 3.
Situation en France : Aucune mesure n’a pour l’instant détecté le passage de radioactivité en provenance du Japon.
| Sujet: Re: Les informations Ven 25 Mar 2011 - 9:34 | |
| Bonjour Les deniers communiqués de la CRIIRAD concernant la contamination en France :
D’après les modélisations des trajectoires des rejets radioactifs de la centrale nucléaire de Fukushima Daiichi, les masses d’air contaminé seraient arrivées hier sur le territoire français. Les comptages effectués cette nuit sur l’air prélevé hier dans la Drôme n’ont pas révélé de contamination. Sur la vallée du Rhône, où le laboratoire de la CRIIRAD gère un réseau de 5 balises d’air, les analyses effectuées sur les dispositifs de filtration montrent que, dans l’hypothèse où la contamination de l’air aurait augmenté, elle n’est pas encore détectable. Les résultats sont valables pour l’air respiré par les habitants du sud-est de la France les lundi 21 mars, mardi 22 mars et mercredi 23 mars (jusqu’à 15h).
Dans un précédent communiqué, la CRIIRAD avait essayé d’anticiper les niveaux de risques en effectuant diverses hypothèses pour pallier le manque de données utilisables. Elle pourra désormais donner des évaluations plus fiables sur la base des résultats de son laboratoire. Concernant l’iode 131, radionucléide pilote pour le risque de contamination par inhalation, les premiers résultats (lundi à mercredi) permettent de garantir une activité inférieure à 300 μBq/m3 (soit 0,3 mBq/m3). Sur cette base, la CRIIRAD confirme que le risque associé à l’inhalation de l’air contaminé est très faible et ne justifie pas la mise en œuvre de mesures de protection, que ce soit le confinement ou la prise d’iode stable (même en projetant le calcul sur 3 semaines aux mêmes niveaux d’activité).
Allons plus loin et complétons par un calcul cette estimation de la CRIIRAD : Imaginons que le nuage reste pendant une semaine avec une activité volumique de 1 mBq/m3. Un bébé qui respirerait à 0.3 m3/h pendant cette semaine incorporerait 50.4 mBq En prenant le coefficient de dose par unité d'incorporation (calculé pour une dose efficace engagée de 1 mSv) soit 1,8.10-7 Sv/Bq on obtiendrait une dose efficace de 9 nanosievert et une dose à la thyroïde de 0.18 µSv. A comparer bien entendu à la radioactivité naturelle qui délivrerait pendant la même semaine 56 µSv à bébé ! Soit 6000 fois plus !
Le risque pour moi n'est pas très faible, il est NUL ! KLOUG |
| Sujet: Re: Les informations Ven 25 Mar 2011 - 9:42 | |
| Bonjour Réunion extraordinaire du Haut comité pour la transparence et l’information sur la sécurité nucléaire suite à l’accident de Fukushima 24 mars 2011 Le Haut comité pour la transparence et l’information sur la sécurité nucléaire (HCTISN) s’est réuni ce jour en séance plénière extraordinaire, afin d’entendre les principaux acteurs français impliqués dans le suivi de l’accident nucléaire de Fukushima, dont l’Autorité de sûreté nucléaire (ASN), l’Institut de radioprotection et de sûreté nucléaire (IRSN), EDF, le CEA, AREVA et le ministère de l’écologie et du développement durable. Au cours de cette réunion, des exposés ont permis d’aborder : - le point de la situation à Fukushima, - le fonctionnement des réacteurs accidentés, - les rejets radioactifs et leurs impacts au Japon et dans le monde. Par ailleurs, le Haut comité a examiné le processus d’information du public mis en place par les autorités françaises à l’occasion de cet accident. Le Haut comité estime que ce processus s’est révélé satisfaisant et que les efforts de transparence des différentes autorités françaises sont à souligner. Enfin, le Haut comité a été informé de la saisine, ce jour, de l’Autorité de sûreté nucléaire par le Premier ministre, aux fins d’engager sans délai l’audit des installations nucléaires françaises à la lumière des événements japonais. Comme l’a exprimé le Premier ministre dans cette saisine, le HCTISN contribuera à toutes les étapes de ce processus. Les documents exposés sont immédiatement disponibles sur le site internet du Haut comité : http://www.hctisn.fr/et le compte-rendu des échanges qui ont suivi y sera également publié après approbation lors de la prochaine séance plénière de juin 2011. KLOUG |
| Sujet: Re: Les informations Ven 25 Mar 2011 - 10:24 | |
| Article du Figaro.fr ce matin
Fukushima : la cuve du réacteur n° 3 pourrait être endommagée
L'opérateur de la centrale nucléaire de Fukushima, Tokyo Electric Power (Tepco), a reconnu, vendredi 25 mars, que la cuve du réacteur n° 3 qui contient les barres de combustible, pourrait être endommagée. "Des substances radioactives se sont échappées loin du réacteur", a de son côté expliqué Hideyuki Nishiyama, porte-parole de l'Agence japonaise de sûreté nucléaire. "Selon ce que semblent montrer les analyses, nous pensons que la capacité de confinement atteint encore un certain niveau, mais il y un fort risque que le réacteur soit endommagé", a-t-il ajouté. Quatre réacteurs de la centrale de Fukushima ont été gravement accidentés après la catastrophe du 11 mars.
Les opérations de refroidissement des réacteurs à l'aide de canons à eau et les travaux de rétablissement de l'alimentation électrique avançaient lentement en raison de la dangerosité du site, au lendemain de l'hospitalisation de deux ouvriers gravement irradiés.
"Nous en sommes encore à évaluer les dégâts sur la centrale et nous ne pouvons par fixer une date à laquelle les équipements de refroidissement vont fonctionner. Cela pourrait prendre encore plus d'un mois, qui sait", a déclaré un porte-parole de la société. L'Agence japonaise de sûreté nucléaire a par ailleurs annoncé qu'elle n'écartait pas la possibilité de relever à 6 le niveau de l'accident de Fukushima, actuellement fixé à 5, sur une échelle allant de 0 à 7.
L'Agence a dans le même temps reproché à Tepco de ne pas avoir pris les mesures nécessaires pour protéger ses techniciens qui luttent jour et nuit au côté de centaines de pompiers et soldats pour éviter une catastrophe nucléaire. Selon un porte-parole de l'Agence, "des substances radioactives ont fui du réacteur 3, qui pourrait avoir été endommagé".
Trois ouvriers, chaussés seulement de bottines en caoutchouc, ont été contaminés jeudi par une flaque d'eau très fortement radioactive lors d'une intervention dans la turbine située derrière le réacteur 3. Deux ont dû être hospitalisés avec des brûlures aux pieds. Au total, 17 ouvriers ont été exposés à des radiations supérieures à la limite autorisée depuis le 11 mars. Le gouvernement a ordonné à Tepco "d'améliorer la gestion du personnel, afin d'empêcher la répétition de ce genre d'accident", a déclaré vendredi le porte-parole Yukio Edano, demandant qu'une enquête soit menée pour expliquer "comment les ouvriers ont pu être exposés aux radiations".
Vue de la centrale de Fukushima, le 23 mars 2011.
Vue de la centrale de Fukushima, le 23 mars 2011.REUTERS/KYODO
CONTAMINATION ALIMENTAIRE
En attendant que les pompes de refroidissement soient remises en service, des fuites radioactives continuent de s'échapper périodiquement des quatre réacteurs les plus gravement endommagés, nourrissant la peur d'une contamination de la chaîne alimentaire et de l'eau dans la région de Tokyo, où vivent quelque 35 millions de personnes, et même à l'étranger. La vente de certains légumes verts et de lait cru dans au moins quatre préfectures autour de la centrale de Fukushima a été interdite, tandis que l'eau du robinet a été déconseillée pour les enfants en bas âge dans une douzaine de localités autour de la capitale. Le ministère de la santé a également renforcé les contrôles sur les poissons et mollusques pêchés au large de la centrale.
La peur des radiations nucléaires s'étend aussi au reste de la planète. Le nombre de visiteurs étrangers arrivant à l'aéroport international de Narita, près de Tokyo, a baissé d'environ 60 %, entre le 11 et le 22 mars, par rapport à la même période l'an dernier, a indiqué le Bureau de l'immigration. Le nombre d'étrangers fuyant le pays a lui augmenté de 20 000 personnes pendant ce laps de temps. Après les Etats-Unis, l'Australie, le Canada, la Russie, la Chine et plusieurs autres pays d'Asie, les 27 pays de l'Union Européenne ont décrété à leur tour des contrôles sur les produits frais en provenance du nord-est du Japon, qui n'ont désormais pratiquement plus de débouchés à l'étranger. Perspectives de redressement selon le FMI
Le rétablissement de l'approvisionnement en énergie et les dépenses publiques de construction sont deux éléments cruciaux pour que le Japon reprennent le chemin de la croissance, a estimé jeudi le Fonds monétaire international. Des représentants du FMI ont expliqué lors d'une conférence de presse qu'ils s'attendaient à un ralentissement de la croissance à court terme du Japon mais que celle-ci rebondirait à des niveaux précédents le séisme, et au-delà. Mais la possibilité d'une pénurie durable de courant, due à l'arrêt de la centrale nucléaire de Fukushima Dai-Ichi, la fermeture d'autres centrales et les menaces de radiation émanant de Fukushima, complique les perspectives de redressement. - (avec AFP)
Deux Japonais hospitalisés en Chine Deux Japonais ont été hospitalisés après leur arrivée mercredi en Chine en provenance de Tokyo sur un vol commercial parce qu'ils présentaient de "graves" taux de radioactivité, a annoncé vendredi l'Administration chinoise chargée de la sécurité et de la quarantaine. Auparavant, seul des cas de Japonais présentant des taux anormaux de radioactivité ont été annoncés à Taïwan, le 17 mars, après les accidents en chaîne à la centrale nucléaire japonaise de Fukushima. Ces deux Japonais résidaient dans un rayon de 200 à 350 km de la centrale nucléaire, très endommagée par le séisme et le raz-de-marée du 11 mars, dans l'est du Japon. Les deux voyageurs ont été hospitalisés dans la ville de Suzhou "pour recevoir un traitement", précise l'Administration sur son site, et "leurs bagages et vêtements ont été détruits". - (avec AFP)
KLOUG |
| Sujet: Re: Les informations Ven 25 Mar 2011 - 14:05 | |
| Je voudrais faire part d'un fait étrange qui s'est déroulé entre hier et aujourd'hui, et savoir si l'un(e) des inscrits au forum est au courant. Hier, sur le site européen de balises de détection http://eurdeppub.jrc.ec.europa.eu/eurdeppub/home.aspx# (que j'ai trouvé sur ce forum, merci), j'ai remarqué qu'une des stations en Grèce, Ionnina au nord-ouest, indiquait des valeurs relativement élevées supérieures à 400nSv/h (gros point violet sur la station). Les données temporelles indiquaient en effet un accroissement très rapide à partir du 23 après-midi, passant de 80 nSv/h à environ 1 mSv/h (0.001 Sv/h). C'était la seule balise à atteindre des valeurs > 400nSv/h sur toute la carte de l'Europe. J'ai tout de suite adressé un email au "Task leader Data and Information Exchange" du site pour m'informer. Je n'ai toujours pas eu de réponse, peut-être n'était-ce pas la bonne personne à contacter. Bizarrement, depuis ce matin la station a été retirée du site ainsi que les données, et malheureusement je n'ai rien enregistré sur le moment. Est-ce que par hasard quelqu'un était au courant, et qu'en pensez-vous? |
| Sujet: Re: Les informations Ven 25 Mar 2011 - 14:32 | |
| Je viens de regarder, la station et les données sont dispos jusqu'au 24/03 à 03h00. Il est tout à fait possible que se soit juste la balise qui soit tombée en panne, (détecteur HS par exemple). En tout cas ils devraient te répondre ou on devrais avoir l'explication dans les news du site eurdep (c'est ce qu'ils font en général) [img] [/img] |
